Results 1 to 16 of 16
Thread: Kleiner Mod
    Calgary, Canada
    Kleiner Mod
    I heard Mr Kleiner has a method of securing the wheel centre cap with a set screw. Would anyone have a photo as I can't see where to put a set screw.
    Finally started my build the beginning July. 2015!
    Senior Member DaleG's Avatar
    Mar 2013
    Here's how I did mine: from inside, drilled/tapped 3 set-screws at 120 degrees.017.JPG
    Or you can stick a chunk of pool noodle behind it.
    Raleigh NC, OIB NC
    Or Silicone.
    Kevin
    MKIV #8234
    Here:
    Calgary, Canada
    Thanks guys. I used silicone and it appeared to work great until I had to take rims off. All came off ok except one. The silicone didn't hold and everything turned together!
    Jeff - do you have to drill at an angle?
    Aptos, CA
    If you don't use the fake wheel nut cover, the spinner doesn't need to be removed. At least on my Team III's they don't. Just loosen the spinner and move it as you remove the nuts. Wheel comes off with the spinner attached. I've even had to use a dead blow hammer to knock the center out after removing the wheel. All this without the need for any type of locking stuff or goo. jmo
    www.weendoggy.com/cobra.htm
    Senior Member canuck1's Avatar
    Victoria, BC CANADA
    Too many "Kleiner mod(s)"! I think we need to create a reference directory to categorize each of them!
    Sean
    MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
    So. Bay (So. Calif.)
    Quote Originally Posted by canuck1 View Post
    Sean
    And so far, I think I've done 'em all. The front turn light o-ring is my F-A-A-A-AVORITE. Thanks Jeff.
    And so far, I think I've done 'em all. The front turn light o-ring is my favorite. Thanks Jeff.
    I can not wait to do this one.
    Calgary, Canada
    I don't know that one! The rear QJ mount mod is great!
    Senior Member jrcuz's Avatar
    Stafford Virginia
    Da Bat doesn't call him Capt O Ring for nothing!
    JR
    Calgary, Canada
    someone tell me what that o-ring mod is please!
    The front parking light/turn light fixture does not sit flat or flush with the body. There is a gap between the chrome ring around the lens and the paint/body. A big o-ring seals up that gap. I think this is the part. #9558K128 https://www.mcmaster.com/#orders/=18gxqpc Rumor has it that this is JK's world's greatest mod.
    Stafford Virginia
    I got mine at True Value hardware 2 3/4" $1.35 ea.
    JR
    Chop,
    Where ya' been man? I thought everybody knew this by now and the dead horse had finally been beaten sufficiently
    http://www.ffcars.com/forums/17-fact...t-upgrade.html
    Whatever you do don't tell Miller that the horse is back up and trotting around the pasture
