I heard Mr Kleiner has a method of securing the wheel centre cap with a set screw. Would anyone have a photo as I can't see where to put a set screw.
Here's how I did mine: from inside, drilled/tapped 3 set-screws at 120 degrees.017.JPG
Or you can stick a chunk of pool noodle behind it.
Or Silicone.
Kevin
MKIV #8234
Thanks guys. I used silicone and it appeared to work great until I had to take rims off. All came off ok except one. The silicone didn't hold and everything turned together!
Jeff - do you have to drill at an angle?
If you don't use the fake wheel nut cover, the spinner doesn't need to be removed. At least on my Team III's they don't. Just loosen the spinner and move it as you remove the nuts. Wheel comes off with the spinner attached. I've even had to use a dead blow hammer to knock the center out after removing the wheel. All this without the need for any type of locking stuff or goo. jmo
Too many "Kleiner mod(s)"! I think we need to create a reference directory to categorize each of them!
Sean
MK 3.5 roadster (MK IV body retrofit to MK III chassis) 396W stroker, 4 bbl mass air EFI, QH (self-tuned), AFR 195CC Renegade, XE274HR, GP 4-1-4 SS headers, 3link, 3.73, 15" Halibrand replicas, SAI mod, bumpers, 2 X roll bars, IČ electronics, PS, hydroboosted brakes: 95 GT front, custom MK VIII calipers/Cobra discs rear, FFR front, Levy rear LCA's, Forte front, VPM rear bars, CF dash, mod comp layout w/Auto Meter Ultra-Lites, Lucas tri-bar headlights, coupe taillights, painted by SRP (again!)
Da Bat doesn't call him Capt O Ring for nothing!
JR
someone tell me what that o-ring mod is please!
The front parking light/turn light fixture does not sit flat or flush with the body. There is a gap between the chrome ring around the lens and the paint/body. A big o-ring seals up that gap. I think this is the part. #9558K128 https://www.mcmaster.com/#orders/=18gxqpc Rumor has it that this is JK's world's greatest mod.
I got mine at True Value hardware 2 3/4" $1.35 ea.
JR
Chop,
Where ya' been man? I thought everybody knew this by now and the dead horse had finally been beaten sufficiently
http://www.ffcars.com/forums/17-fact...t-upgrade.html
Whatever you do don't tell Miller that the horse is back up and trotting around the pasture
