Results 1 to 3 of 3
Thread: FFR Fuel Filter
    Senior Member jwebb's Avatar
    Longmeadow, MA
    FFR Fuel Filter
    Is the filter supplied in the kit for EFI/electric & mechanical fuel pumps? I've seen with a mechanical pump the filter is between the pump & car ..
    It is a Ford EFI unit.
    Senior Member smithbks's Avatar
    Mar 2014
    Atlee, VA
    Stupid question, but does that mean it is a problem on a carb with a mechanical pump?
    I deliberated this when I built it but decided I liked having the secondary filter as well. The filter near the tank is bigger (and I'm used to it from the old 5.0) and the filter upstream at the mechanical pump is a little bitty thing.
    Mk4 #8340, 351w/427, 3-link, Wilwood 4 piston rear brakes, 3.27 gear, TKO600, delivered June 18th, 2014
