iac valve condition at ig switch help?
Does anyone know if the engine IAC valve is supposed to be closed( i mean extended into the hole) when you turn the key power on?
I am trying to get my IAC to talk to my Tec S computer. If it does not close during startup the engine will try to idle at 5000 rpm . I know it is the 4th wire on the main harness or the yellow / green wire. The other wire to the valve is a 12v switch on wire.
Note : my engine is a 2002 impreza non turbo version 2.2liter.
thanks to anyone,
kerry sylvester
e mail : [email protected]
