Results 1 to 2 of 2
Thread: 818
    CA
    818
    USA
    I have a non-dccd JDM 6 speed. It came out of a forester STI. You should be able to use your axles. The shift mechanism will require some work. You also need to disable the reverse lockout or add a separate cable to actuate it. Your flywheel and clutch are reusable. The center diff will need its spiders welded up. You should pre-heat this before welding the snot out of it.
