Results 1 to 14 of 14
Thread: Coupe Door Lock
Hybrid View
    Nov 2016
    Coupe Door Lock
    Hi all-
    I can't figure out the drivers door lock linkage to make the outside key work. Has anyone had success with this and are there any pictures?
    Thanks!
    Mar 2015
    Belmar, NJ
    I have been working on this for a few days.
    Will post when I have fully figured it out. If the linkage is to "tight" the lock will not work.
    818S #343 Delivered 5-20-2015
    First Start 10-17-2015
    First Drive 10-17-2017 ( 100 feet back and forth until I can get off driveway)
    First Drive with a non leaking tuned motor 11-12-2015 (wow)
    Passed NJ State constructed inspection 8/30/2016
    Jan 2012
    Any luck? I gabe up and decided to use the oe electric locks paired to my alarm and run a release cable if the battery dies
    Senior Member TX-Lou's Avatar
    Just got to this stage ourselves this weekend. Did you guys figure out anything. How are you connecting the metal piece that turns when you turn the key to the actual lock mechanism in the door? They are about 2 to 3 inches apart and I don't see anything that came with the kit to connect them.
    Building an 818C
    Ordered: 8/31/15, Production Date: 1/23/16, Delivery Date: 2/05/2016
    First Start: 4/14/2017
    818C Build Thread
    Donor Teardown Thread
    Administrator
    Wayne Presley's Avatar
    Enterprise Alabama
    I just did one and I flipped the key cylinder upside down from the instructions, made a new straight link to replace the FFR"L" shaped link and it works great.
    Mar 2015
    Belmar, NJ
    wish i thought of that
    I found electric locks and made the change. Glad i did.
    Nov 2016
    Could you take a couple of pictures, Wayne? I never made mine work.
    Administrator
    Enterprise Alabama
    Quote Originally Posted by CBlake View Post
    I'll do it tonight
    I'll do it tonight
    Thanks Wayne! That would help a lot.
    - Lou
    Building an 818C
    818C Build Thread
    Administrator
    Enterprise Alabama
    Upside lock cylinder
    New link
    Tab trimmed off for clearance on FFR supplied lock knob
    Center tab still on
    Thanks Wayne!
    Is that linkage screwed down tight or did you allow it to rotate freely?
    - Lou
    Building an 818C
    818C Build Thread
    Administrator
    Enterprise Alabama
    Quote Originally Posted by TX-Lou View Post
    Thanks Wayne!
    - Lou
    Linkage is just loose.
    Thanks Wayne!
    - Lou
    Building an 818C
    818C Build Thread
    Nov 2016
    Thanks Wayne!
