Not sure what else to try out here, so thought one of the experts on the forum could help. I have the Russ Thompson wiring harness from Factory Five. I am making sure all the lights are working before I put the body back on. Everything works EXCEPT the turn signals. I have replaced the fuse and the flasher to no avail. So I turn the car key to the on position and turn the turn signal switch to right/left and put my test light on the flasher wire in the fuse box and I get no light (as can be seen in the picture). Same result with the fuse. So it doesn't seem like i am getting power but if that is the case I am not sure what to try next. Appreciate the help.
Mark
