Results 1 to 13 of 13
Thread: Rivnut
    Burlington, WI
    Rivnut
    I while back I purchased riv nuts in the size of 5/16 - 18. Buying a tool to handle this size is a bit excessive for my budget. Does anyone have an alternative solution.
    Road Legal August 31, 2017
    Banned
    Loveland, CO
    Maybe. You'd have to explain the application. I bonded stainless steel or home made aluminum nut plates to my fiberglass body to mount some parts. I also drilled and tapped the frame to mount other items. Fine threads are better, when tapping thin (1/8") materials.
    I use this style installation tool from McMaster. I have several sizes including the 5/16 - 18. Relatively cheap, simple, probably will never break or wear out, and works every time. https://www.mcmaster.com/#96349a407/=18myjga
    Senior Member Rodster's Avatar
    Orange County, CA
    x2. See a tutorial of this exact thing:
    https://wayne-yoshida-kh6wz.com/2013...lerator-pedal/
    Ordered Type 65 Complete Kit Aug 29, 2012 - The 50-50 $ale!
    Standard Width IRS; Halibrands - 17x9, 17x10.5
    Kit Arrived: Oct 9, 2012; Build Started: Oct 28, 2012
    WordPress: http://wayne-yoshida-kh6wz.com/
    LinkedIn: www.linkedin.com/in/waynetyoshida
    YouTube: http://www.youtube.com/user/kh6wz?feature=results_main
    Super Moderator
    Ray's Avatar
    La Mesa, California
    Burlington, WI
    Got it. Now I have options.
    I use the same cap screw, nut, and washer method Ray details above. Been using this method for more than forty-years now for 1/4" and above as I've never used enough at one time to make spending the $$ for a heavy duty tool. It's slow and cumbersome but works. I use a grade-8 cap screw & nut with a hardened washer and plenty of lube. Also, when using rivnuts in plastic, fiberglass, or thin aluminum I use the type that are made for plastic. They look and work like drywall anchors where pedals spread out when tightened.
    A long 5/16" grade-8 bolt, three washers, some grease and a coupler nut works well to install larger rivet-nuts.
    You just need to be able to swing the wrench on the coupler nut to do a rock solid installation.
    The point is you have an alternative that is also inexpensive.
    Good Luck From Da-Swamp Dawlin!
    N.O.L.A. Style Speaking That Is!
    May 2013
    Colombia
    If you're going to be using a lot of rivnuts I'd buy a tool. I'm using the following one with great results:
    https://www.amazon.com/gp/aw/d/B003T...?ie=UTF8&psc=1
    A word of caution. Those small rivnuts may not be able to handle the thickness of the aluminum+frame tubes. You can try to get the rivnuts for thicker metal. They may be hard to find. You need them to handle at least .15".
    Quote Originally Posted by Speedy G View Post
    Here Is A Great Place To Find Any Rivet-Nut You Need & At A Fair Price Too!
    https://www.rivetsonline.com
    Member Frank Messina's Avatar
    Yorba Linda, CA
    I just went through this exercise when mounting my new seats to the Breeze seat mounts. I have had the Marson Riv Nut tool for years and figured I was all set until I tried collapsing one of the 5/16 riv nuts with grip strength alone. Not happening! I now have the tool(s) from McMaster-Carr that edwardb referenced. One each for 5/16 and 3/8.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
    Orange County, CA
    Ray - Excellent! Thanks for sharing the DIY versions!
    Burlington, WI
    Quote Originally Posted by Rodster View Post
    2x. Great DYI. Thanks.
