does anyone know what spring rate the rear coilovers [koni] come with? after driving a bit i'm thinking of going to a softer spring rate.
250lb/in is great for a street driven Roadster
Mark, does Breeze sell the 250lb springs that would fit my 3.1 roadster w/3 link suspension that came with red Koni shocks? Also, can I keep the 500lb front springs, or will they change the handling, with 250lbs in back? I'm thinking perhaps they might act like a front anti-roll bar. Jim
Mk3.1 Complete kit #6846 Delv. 12/20/08-- Finished 2/11/11, 89 302 EFI,T-5, 3-Link, 17" Halibrands, Nitto 555 245-315 tires, widened drivers footbox w/ dead pedal, extended passengers footbox,Sapphire Blue Met & Wimbledon White stripes,radiator stone guard shield, Build blog http://jimsffrcobrabuild.blogspot.com/
Ttt
Thanks, Jeff that was what I didn't want.
Mine are 500lb front and 350lb rear for 3link solid axle. Has anybody moved the 350lb springs to the front and put 250lb springs in the rear? I'm thinking that the 350lb springs might have to be tightened up too much to support the weight of the engine.
FWIW (and it isn't much), but the 33HR now comes with 400 front 250 rear. Not sure how the weights compare between roadster and 33.. presumably quite similar though..
I went down 50 pounds both front and rear and it helped a lot for street use. Summit Racing has Eibachs. I reset ride height after install and added about a 1/4 inch so 5 inches now.
450lb front is a good match for 250 rear. If you have a lighter combo like 302 w alu. heads and a T-5 then 400 front is also nice.
RR
Keep in mind on the 33 that the front control arms have a 1.6ish ratio against the inboard coils so the effective rate is much less at the wheel.
The 33 also used to come with 350 rear but after many complaints about harsh ride they changed the coil over package on the 3 and 4 link coupe.
