Thread: Boyd tank Stealth 340 pump
    Saline, Mi
    For those of you who purchased a Boyd tank for your 818, what has been your experience with the Aeromotive 340 series pump. They say there are 3 of the 340 series
    pumps and not sure which Boyd installs. If it is a 11542 it flows a minimum of 225l/hr which is way more than even a reasonably tuned 2L should need.
    I am thinking it may recycle so much fuel, it may actually heat it or the fuel pressure regulator can not control..
    Any experience one would like to share??
    Feb 2013
    Westminster, MD
    I've been using the Stealth 340 pump for ~10 years now from almost stock 'Stage 2' cars all the way to 650whp monsters. Never had an issue.
    One thing to note, the sock provided is very short and will exacerbate fuel starvation issues. I suggest using the OEM sock.
    wallace18's Avatar
    Trenton, Florida
    Quote Originally Posted by frankc5r View Post
    Frank I used their tank and pump on my 1st 818S,and 2- 33 Hot Rods. no problems at all.
    Saline, Mi
    Thanks for replies. This forum and users are a great help for new builders to Subaru.
    Saline, Mi
    Tom,
    Did u use the stock fpr with your builds or an aftermarket? I worried the stock fpr can't handle the greater flow of the 340.
    wallace18's Avatar
    Trenton, Florida
    Yes I did with no problems.
    Saline, Mi
    Thanks !
