Thread: Rear Suspension Set Up - Godspeed
    I purchased this kit: https://godspeedproject.com/suspensi...-link-set.html
    The spacers are about a good 1/8" too wide to fit. Before I machine them down, anyone else had this issue?
    Mar 2015
    Houston, Tx
    Quote Originally Posted by BrianToronto View Post
    Yes. Everybody that has ordered them has had this problem. Some cut them down and some get a bar and widen the brackets.
    Go ahead and shave them down. It won't cause a problem.
    Wish these forums were a little more "searchable" but thank you for the quick response. I guess that's what I'll do. The grinder sure gets a workout building this car...
    Harley818's Avatar
    Vancouver BC
    I bought the same product, with the same issue and just cut them down.
    However, I notice you didn't get the trailing link with the kit.
    Mine had the trailing link as well, which allows you to put the wheel right in the center of the wheelwell.
    If you do purchase the trailing link, mount it with a bias towards the inside of the car when you cut the spacers to fit.
    that will give you just a bit more clearance with the wheels.
    My clearance is marginal on one side, and touches when cornering, so I need to move it over a bit.
    Harley
    Bought 2002 Donor Jan 2014
    First Start Jan 18, 2015
    First Drive Feb 14, 2015
