Fuel Filler Neck Ground
Mornin'!
I am getting wildly close to go karting, so I am feverishly wrapping up all the literal loose ends. I have a thin ground strap that came with my kit. I believe it is for the fuel filler neck, but did not see any where in the instructions on where to put it. How do you guys have yours mounted?
Thanks!
Scottie
In the lemans cap hardware there is a 10-32 long bolt that goes in one of the holes. Attach one side to the bottom of that with a nut and the other side to a good ground on the chassis that you can reach.
michael everson
Ahhhhhh! Makes perfect sense. Thanks so much Mike!
Make sure to sand/grind off any paint or powder coat to insure good metal contact. Enjoy!
ricobrafan
Will do. Thanks!
