I think you can see my problem. Isn't the outside trunk wall supposed to be installed before the trunk floor?
The outside wall is not completely drilled yet, the floor is sealed and riveted. I honestly don't think I can remove the trunk floor without wrecking the aluminum, Bostik adhesive sticks very well. My plan was to fabricate the upper inside trunk panels (adding to the problem) and laying insulation and carpeting in the truck anyway.
If I don't fix it what other problems can I anticipate? Any Ideas?
Ken
