Thread: InfinivyBox and CHasis Wiring Harness
    Jun 2017
    I'm considering the InfiinityBox for my upcoming 818s project, But have a couple questions. Has anyone used it along with keeping the ABS brakes? Do you still have to keep parts of the original harness. How about using it with the instrument cluster. I'm supposing you still need part of the original harness to take any ecu error codes to dis[lay them on the engine warning light?
    The InfinityBox relly looks like a great product but just wondering how much of the original harness do you keep?
    Glenn
    Feb 2013
    Westminster, MD
    Quote Originally Posted by grathke View Post
    Glenn
    If you're refereing to the AEM Infinity you will want to make absolutely sure it will work with your setup. They DO NOT work with the 2.0L engines as they cannot use the cam/crank pattern from the 205 engines. If you have a later model engine/harness/ecu they can be adapted to work.
    Reno, NV
    I'm considering using it (the InfinityBox PDM). But I haven't gotten to the wiring yet so I can't answer your questions. IIRC there was someone on here that has used it.
    818R Build date 10/31/15
    This IBox: www.infinitybox.com
    I have that along with inTOUCH. But I do not have a Subaru drivetrain nor cluster, so I cannot answer your question. However Jay asked me the question if I was using ABS and I am not.
    What is the problem with ABS and changing the wiring? What is your concern? Do you need to plug something from the ABS to IBox?
