Thread: Weatherstripping for Interior Dress Up?
    I need some help finding what I am looking for: I had to cut a 2005-2007 WRX center console and I am looking for a way to dress up my cut lines. I dropped by Ace Hardware to see what I could find, and didn't have much luck. The closest thing I found to what I am looking for is weatherstripping for a garage door... :-/
    I'm searching for something that I can use to seal the gap between the center console and the dash.
    Thanks!
    San Diego Ca 92106
    You could make a fiberglass piece that can be made to fit. You can then use it for switches or more gauges or....
    I think I found what I was looking for - McMaster-Carr for the win! I think the plan is to utilize "bulb seals" or "trim molding."
    I LOVE the way that console looks in there. My plan, too, and I wasn't sure.
    Aug 2012
    Long Island
    can you just clean up your cuts a little and raise the front of the console slightly until it touches the dash?
    What seats are those?
    Quote Originally Posted by axelthrasher View Post
    Thanks!
    The console looks really really great.
    Did you have to cut out any portions of the steel structure that goes from front to rear, that is, the portion you usually mount the shifter to.
    Along with the console and dash/radio bezel, did you purchase any supporting metal framework? Or did you just purchase the console pieces and fabricate your own mounting points.
    Do you have any pictures of the process along the way?
    Glenn
    I like the Subie console. More civilized feel.
    What door panels are those?
