Thread: Air cleaner and valve covers.. which ones
    I'm running a 351w with performer RPM intake and a spacer under my quickfuel 750. I want to go with the oval cleaner and cobra valve covers. I have read some info about valve cover clearance with some of the covers. Anyone have a part number listing that I should be looking for. I have also seen different sizes with regards to the air cleaner assemblies. I'm looking for some real world advice here and need to act fairly quickly. I'm about a solid weekends worth of work away from being ready for paint. I'd like to pop the filter on and check clearance before sending it off.
    Santa Clarita, CA.
    I was looking for covers that say cobra or cobra power by ford... any clue on those?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Santa Clarita, CA.
    Did you check the links I posted. Both the valve cover and air cleaner say cobra on them. Am I missing something?
    427 cobra on the one.. was looking for some without 427 on them.
    Ohio
    I got my motor from engine factory with Cobra oval air cleaner and 427 Cobra Ford Powered finned valve covers. Contact them and see if they sell them.
    JRL16
