LCA help
I need some help. I noticed on my finished car that the rear bushings were not on correctly, plus I decided it was a good opportunity to rotate the bushing pin for a little more caster. I managed to get things apart but I'm having problems getting the bolts lined up to get the bushings back in their brackets. I need to loosen up the LCA so that I can get it to move a bit outward. What do I need to disconnect? The top shock mount? Upper A arm? Sway bar? all of the above? It's a pain with all the splash panels in, I may need to drill some out for better access.
