Here's a question for the pros regarding centering our non-symmetrical bodies on the frame. I believe this may have been mentioned but not the focus in threads. I have the body centered on the frame as viewed from the engine compartment. Meaning, as I look at the engine bay, the body appears centered on the upper frame rails. To achieve this, I pulled the front of the body to the right before securing the quick jack bolts. As a consequence, the left front wheel is slightly outside of the wheel well and the left exhaust flange is showing in the exhaust cut out. And, needing to pull the panel in front of the driver's door in may be adding to the exposed exhaust flange.
So...if I can live with the engine bay/ body alignment not looking perfect, I think I can remedy the wheel well and exposed flange issues.
I thought I would ask before I begin loosening things up and making adjustments.
