0
0
Cockpit Sheet Metal Fitting Problems
I have spent the past few days placing and drilling the cockpit sheet metal. I have followed the assembly sequence in the manual and am on the last piece, the back wall. It is giving me some problems. First the seat belt slots in the sheet metal are not even across the back with the chassis cut outs. It varies a little more than 1/16" passenger side to driver's side. Is this common? I don't think I can get it closer.
As well, see the pictures below, the rear corner piece and the back wall sheet metal at the top do not match up. It's about 1/4" at the top to 0" where the bend starts. Again, is this normal? Is it going to create a problem later? I can't get it closer without distorting other pieces.
Help!!!
