0
0
Transmission Speedo Plug
Hey Everyone!
My father came over yesterday to help wrap up some wiring while I finished some other odds and ends. We threw the passenger seat in, lap belts, and went for an actual drive around the neighborhood.
The car drives amazing, granted this is at 20 mph. It also wants to rip the rear tires off and make amazing sounds. Another great trick it does is blowing ATF out of the speedo sensor hole in my T5 I rebuilt and all over the damn place.
Live and learn. I am finding a couple of speedo sensor plugs, but quite frankly, I don't need to spend $30 on a billet plug no one will see. Can you guys let me know what you use for the speedo sensor plug on the T5? This is for the hole on the driver side in the tail housing.
Thanks!
Scottie
Get in touch with Bob at Hanlon Motor Sports @ http://hanlonmotorsports.com/
He will score you a OEM speedo switch and ship it to you.
Originally Posted by
RickP
THanks Rick!
MK IV Roadster #8631
phileas_fogg
Thanks! I decided to just call Mike Forte and tell him to send his plug over.
- You may not post replies
- You may not edit your posts
Forum Rules
