Results 1 to 3 of 3
Thread: Gen 3 coupe TKO mid shift
    Edmonton Alberta
    I have not installed the engine/transmission yet but it looks like the new Gen 3 coupe is set up for a mid shift. My car has a TKO600 behind a Dart block 363
    Do I need to modify the TKO600 to mid shift for the supplied transmission cover to fit?
    David W
    Maricopa AZ
    You don't need to mid shift the trans. Everything is forward of the last gen car.
    Shoot be a call tomorrow please.
    Edmonton Alberta
    I thought I should close this off, after further measuring and checking this is what I discovered.
    The Coyote engine sits further forward and uses a drive shaft about 3 inches longer, 13.xx vs 10.xx long for the traditional small block Ford engines. For my car the mid-shift moves the shifter to the correct location to fit the transmission cover. The transmission mount is reversible to work with both engine set ups.
    David W
