Results 1 to 2 of 2
Thread: horn switch connector?
    Saline, Mi
    There seems to be some confusion on my donor as to where the horn switch connector.
    Serv/wiring manual says it is conn B68 expected to be on column where B71(lighting), B69 (parking) B70 (wiper) and B71 (ign) are
    but I can't find B68, a 6 pin conn , page WI-61 in manual. B68-pin 1 connects to horn relay(MB5). It also has cruise control switches but my car
    has a ribbon conn coming out bottom with the cruise wiring and air bag actuator wiring. That conflicts with missing B68 connector.
    The GR wire of B68 and my ribbon is the common side of the cc switches and also goes to horn relay but when I test contact between the GR
    wire and ground wire, I get nothing. Suppose it could be bad but I suspect there is something I am not aware of.
    Ideas??
    May have to pull off airbag and have a look.
    Thanks.
    Saline, Mi
    Pulled it apart and bracket the spring loaded contact is supposed
    to ground to is not ground. It tries but not enough
    to work. Used one of the cruise wires for ground
    and all works now.
