Thread: Coyote "Ghost Ide" tune
    Member Race Ratz's Avatar
    Harwich, MA
    Anyone try it? Who's tune did you use? Thanks, Bill
    Lund Racing knows these engines well. Has been used very successfully by several forum members here, and is recommended by Ford Performance. I haven't personally done their ghost idle, but I recall it was one of the services they offered. Contact information is on their website. https://www.lundracing.com/.
    Senior Member Duke's Avatar
    Taxachusetts
    I have it from Lund, but I don't use it. When I first flashed with it (winter/cold weather) it wouldn't live at idle. Apparently there's some differences in the factory mustang vs the crate motors. Jon mentioned that it works fine with the crate motor and the boss intake though. I asked if Jon could spend some time (at my expense) and see if he could get it sorted out but the basic response was no, it's a novelty.
    When it was running at idle though I was a little concerned about how violent it was and clearance issues. Something to consider if you have side pipes. That's a lot of weight hanging on the headers.
    Senior Member H R Lucky's Avatar
    Jun 2012
    CrossRoads, Pa.
    What is a 'Ghost Idle' Tune?
    Nevin, AKA H. R. Lucky
    33 Hot Rod sn 524 build started 3/18/2013, First Start-5/09/2015, Go Cart-6/01/2015
    5.0 Coyote engine, 9in. Ford rear, 4 Link, Wilwood 12in. front brakes
    AC, power steering, FFR 17/18in. Hot Rod wheels
    Quote Originally Posted by H R Lucky View Post
    A custom tune that uses the variable cams in the Coyote to give a lopey idle along the lines of an old school motor with a big cam. If you're into that sort of thing. Search YouTube if you want to hear some examples.
    Jun 2012
    CrossRoads, Pa.
    Thanks for the quick reply Edward. I'll check it out.
    Nevin
