Jump Posts and General Electrical and Fuel Safety Questions
Good morning everyone. I recently installed the battery into the floor of the trunk and and while I was in there I also put in some external charging posts as well. Still working through getting everything to fit in the battery box and attaching the charging posts to the battery terminals (may need a longer nut on the positive battery terminal, unless anyone has other suggestions on wiring).
My question is safety, which is paramount for me on this build. I want to minimize any chances of electrical (or fuel for that matter) fires. What should I do to limit the chance of an electrical fire in this type of set up or with a Roadster build in general?
For a little more information, I have a heavy duty starter solenoid also located inside the trunk behind the passenger seat.
Mark
