Results 1 to 10 of 10
Thread: OMG! My paint!
    Woodstock ,Illinois
    OMG! My paint!
    On my way to a Cars/Coffee yesterday and passed though a couple construction zones. I passed through some kind of mist that covered the car with SOMETHING that feels like sand. It's not water soluble. I tried some degreaser in a hidden spot. It did the job after some rubbing, but don't know if it's safe! I know I have plenty of work ahead, but what's safe to get this stuff off?
    Hey Sten!
    Well that sucks I'd try a clay bar.
    I concur...clay bar....most likely paint overspray.
    Lost Wages, Nevada
    On older paint types, we used acetone to clean away [non-water soluble] bugs and road tar damage. You might want to try that in a hidden spot to verify that the acetone doesn't effect newer style paint materials.
    CobraboyDR's Avatar
    Jun 2017
    It could be concrete overspray.
    Put the vehicle in cool shade and wash it. Use full strength vinegar, spray it on liberally to the concrete spots, wait 5 mins, repeat until it begins to soften. Then lightly rub it off with a soft rag. If some areas are still hard, Repeat as necessary. It'll come off. Be patient.
    My Explorer was sprayed with concrete while parked on the street here in the DR leaving maybe 25 hard blobs. The above worked very well.
    Good luck!
    Woodstock ,Illinois
    Whatever is on there is undetectable until you put your hand on the car. Looks like a good wash and claybar to the rescue!!
    Thanks all! Really didn't want to use any type of solvents! Off to Wally World!
    Banned
    Loveland, CO
    Acetone should not affect modern urethane paints, but it will dissolve lacquer or enamel, immediately.
    Woodstock ,Illinois
    Well, I ran out to Walmart and picked up a Mother's clay bar kit. WOW! That crap flew off the car! It's soooo smooth I almost don't want to put anything on it! But I will of course. Thanks for the tip!
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Sten,
    Bummer to hear this happened after our event - glad you made it down to the market and even more glad that you got the smeg off your car!!!
    Later,
    Mk3.1 #7074
    Woodstock ,Illinois
    Smeg- free is a good thing! It was fun to get together Chris!
