I have 3000 miles on my coyote with a trimec TKO 500 attached to a QuickTime bell housing. The past 2000 miles I have noticed after a long drive a couple drops of oil on the garage floor coming from the transmission bell housing mounting point. If I wipe the spot off the floor after the car cools down it can sit for weeks without dripping again. I checked the fuild level and top vent all good. The car is all complete and ready for Jeff Kleiner to paint soon as I gets ready for me. My question is should I pull the engine and replace the Transmission front seal if that is even the leak source or just live with two drops of oil after each drive. Jeff if you are reading what would you do??
Dan
