Results 1 to 3 of 3
Thread: Tach input to dash combo
    Saline, Mi
    Does anyone who is not using the stock ecm
    confirm which of the dash input connectors,
    a110, b111, or c112 is the tach input. It
    appears to be A5, labeled as ecm in the
    diagrams. Thanks.
    Quote Originally Posted by frankc5r View Post
    diagrams. Thanks.
    Maybe this will help you out. from 2002 service manual. other years are different.
    Saline, Mi
    Thanks Bob. Those are the diag I was referring to
    in which i110-pin A5 is labeled as ecm right below
    the drawing of tach. VSS is labeled right below
    the speedo and thus possibly infers A5 as tach
    pin, I hope.
