Results 1 to 3 of 3
Thread: Un-used circuits in fuel tank????
    South Jordan, Utah
    what do you do with the following circuits? (2007 WRX)
    Fuel Temp
    Pressure control solenoid valve
    Drain Valve
    Fuel Tank Pressure sensor .
    Do you need to fake the computer for these ? They are not used in the FFR Tank
    If you have a Cobb AccessPort, or OpenSource, you just disable the codes for them.
    If you are using the stock ECU attach the fuel temp sensor to the side of the tank. It helps with the fuel mapping.
