Results 1 to 4 of 4
Thread: front lower control arm spacing question (MK4)
    Nov 2016
    Trying to install the lower control arm, and here is what I have:
    driver side / forward: no room for spacer - pretty tight fit
    driver side / rearward: 1 spacer on and room for maybe 1/2 of a spacer on the other side
    passenger side / forward: 1 spacer on - tight fit
    pass side / rearward: room for 2 total spacers, one on each side
    Do I fill in the spaces with spacers to get the fit at least close to tight, then torque to tighten?
    Senior Member Paul2STL's Avatar
    Nov 2012
    Tacoma, WA
    I kind of had the same problem I left out the spacers in the front forward mounts and put one spacer in the rear mounts. When you torque them down you will bring it in to fill up the half spacer room. When I shoved a spacer in the front mount its seem to bind up the a-arm, so left it out on both sides.
    MKIV #9122 Ordered kit 5/24/17 received kit 8/11/17 MK4 Base kit +,First Start 4/7/18, First Go-Cart 4/22/18, In gelcoat, licensed and driving 8/11/18. Coyote gen2, T-56, 2015 IRS 3.31, 17" Halibrand replicas w/Nitto NT555 G2, Withby Motorcars power brake kit W/Wilwood pedals, 04 Cobra front brakes, 15 Mustang rear brakes with mods, power steering. Paint Jeff Miller Da Bat, Lexus Spectra Blue Mica W/Toyota Silver Sky Metallic strips. Build thread: http://thefactoryfiveforum.com/showt...Paul2STL-Build
    Aug 2017
    Southern WV
    If I remember correctly if there was enough space for a shim I installed one.
    When I tightened the bolts the tab bent to close the space.
    Rick
    Mar 2017
    On mine, I bent the end back a little on one side so the spacers matched (one each side).
