Thread: Ignition Switch Fitment in FFR Padded Dash
    The ignition switch doesn't seem to want to tighten enough to bring the cylinder flush with the bezel. Has anyone found a solution for this?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    Senior Member weendoggy's Avatar
    Aptos, CA
    Does the switch have the adjusting nut on the other side? If so, you'll need to move it toward the switch body and then tighten the ring. This will be a trial and error part of the never ending build.
    I'm just a victim of a thousand physic wars!
    www.weendoggy.com/cobra.htm
    Quote Originally Posted by weendoggy View Post
    Unfortunately, it doesn't. It's cast pot metal with no depth adjustment.
    Legal: 1/30/2020
    Heart of Dixie, Alabama
    I trial fitted my gauges, light sw and ign sw on the plastic padded dash,,,, same fit. Did not think there were enough threads to get the nut started, but it did.
    Did you get the cylinder flush on yours?
    Legal: 1/30/2020
    Lost Wages, Nevada
    Papa,
    Does the front of the switch have a "raised" area behind the threads for the bezel? If it does, and there is sufficient material there, you can grind down that "excess" and maybe give yourself the needed 1/8" of forward movement.
    Just a suggestion, not all switches have anything to grind down - a different switch might be your salvation here.
    Doc
    No. I will look it over as I take the dash apart.
    I checked the switch today. To flush the switch and nut, the nut has to be run down to about .060 from bottoming out. The shoulder on the switch behind the dash, might be 1/8" thick, not much material to be thinning down for more threads.
