Russ' Garage
Results 1 to 16 of 16
Thread: Hydrocarbons To Noise Saabaru Build Thread
    Hi everyone! I'm really glad to become part of this community. I have been interested in building an 818 for years. With the front end and coupe updates, I become convinced it'd be my next major project. All that was left was for the pieces to fall into place. My background is not mechanical, but I enjoy wrenching, problem solving and driving like my pants are on fire! In preparation for this project, I bought a broken modern sport bike with "some sort of bad engine", dug into it and fixed it. I thought if I can't revive a fuel injected motorcycle, I have no business building a car. My garage is almost equipped enough for this project, but I expect the last pieces will come together without drama.
    I have been debating appropriate donors and searching craigslist/Copart/IAAI for accessible, reasonable donors. Finally, after 2 years, I finally found a "good" donor, and with my wife's understanding, pulled the trigger on a 2006 Saab 9-2x Aero (Saabaru).
    The car has 134,000 miles and an auto trans. Per the previous owner, the engine spun a bearing at 90k and was rebuilt with CP forged pistons, Manley forged rods, Cosworth bearings and forged crankshaft, 1000cc DW injectors and a 20g STI turbo. It also got SS headers, uppipe, downpipe and exhaust. The tuning is done with Tactrix Open Source.
    The down sides are it's an auto, and likely has a blown head gasket (hopefully just the gasket) based on overheating at idle after prolonged driving. There is no apparent mixing of oil and water. Also, the body and interior is beat up. It is not a looker (which is a good thing for me - drove the price down)!
    Up next is sourcing a 5MT to swap and a shop to work in, and ordering a kit! Though not necessarily in that order. I could use the garage, but my dear wife would much rather not, as she can accurately anticipate the amount of mess that I'll make.
    I hope to keep my build thread "clean", as in I won't ask esoteric questions here, but in their appropriate sub forums.
    Aug 2012
    Long Island
    Bonus points for buying the first donor with wirenuts under the hood. LMAO
    good luck with project, do you know if a reputable shop built the engine?
    Quote Originally Posted by Ipassgas View Post
    Thank you so much in advance for doing this. I'd bet 70% of the 818 knowledge on this forum is helplessly buried in 30+ page build threads, though it is getting better.
    As for tools and shop space, I can attest that virtually my entire build was done out of a 3-drawer craftsman hand box. There's a few things like tubing benders and drills that aren't regularly in there, and I took a few parts to work to weld or press something or another, but that was typically more out of convenience rather than necessity. IMHO, it was must more important to have a well stocked hardware store nearby than a world-class shop.
    If wire nuts are good enough for my ceiling fan, they're good enough for my engine bay, right?
    The engine was rebuilt by the PO and his "retired aviation mechanic" buddy, in a shop (per the PO). I figure any information I have is way more than I would have gotten from Copart. Maybe it was done well. Maybe it wasn't. I'll never really know, unless/until something expensive fails catastrophically, or I decide to tear into the bottom end for some reason.
    Also, I think I found a transmission! I just need to get some time to go get it, probably next weekend, pending Hurricane Irma's impact.
    And so I got a transmission. Actually, almost everything to convert the auto to manual. I still need a clutch, flywheel and starter, but that should be it. It's a TY754VN2AA, which looks like it's off a 2002 WRX. From reading the transmission thread, it should work.
    Also, I ordered my kit!!! Production date is 10/28/17, but I may have to move it if I go pick it up. Stewart Transportation hasn't called me back yet.
    Forward!!!!
    Assuming it is indeed from a 2002 WRX you're fine. Make sure you order the proper year half-shafts with your kit, and the correct year clutch kit (the throw-out bearings and pressure plate are different on the earlier transmissions due to them being a pull type clutch slave.)
    Forward!!!!
    I sent them the production order for mine last week as a response to our email thread and haven't heard back either. Wouldn't surprise me if they just got busy. They were really responsive when I was just asking questions, before I even placed my order. I'll probably call late this week if I don't get anything.
    Today's update involves a call to FFR. I changed the half shafts on the order to the '02 so they'll match the trans.
    Man, over a month without "progress". Well, progress has happened. My shop has been located and I moved a bunch of stuff to it. Stewart is supposed to deliver a car on Friday or Saturday, and I have some Kirkey seats on the way. (I decided to not order seats at first so I could decide exactly what I wanted). I just went with the FFR ones.
    And I got a bad misfire on the donor. Cylinder 4. I pulled the secondary air pump (that I was tossing anyway) and installed the air pump block off plates while I was working on it. Car still has a gnarly miss after preliminary investigation, and I've lost boost. It's going to need some work, before I can get to work.
    Gassyman, Welcome to the forum. I've upgraded your account for full access so you can use the pic gallery and update your profile.
    Interesting user ID. Sure you wouldn't rather go by Saabaru?
    Have fun with your build; another one pushing the envelope. Happens a lot around here!
    Christmas came early!
    I didn't have time to inventory, so that'll happen today or tomorrow.
    I have a question! Where are you building it? It looks like a warehouse park of some sort. Is that correct?
    Quote Originally Posted by shinn497 View Post
    That is exactly where I'm building it. My wife said no to the garage (too many cars, and I'll make too much mess). So I found an offsite shop. It's 800 sq ft, with electric (one 240 circuit, two 120 circuits). No water, heat or AC. It's 5 minutes from work, and "cheap". The whole complex is probably a dozen units. Mine's the smallest. There is also a full time Honda mechanic, a surfboard/paddleboard maker, a guy who has a "buy here, pay here" place that fixes his personal collection, and a "motorcycle club" headquarters. It should be more than I need to get this car built!
    And as for progress, I have successfully removed all the fiberglass parts from the frame and inventoried 2 whole boxes! Man, I wish I didn't have to work.
    Someone please get this man an award! He actually knows how to use a forum!
    That is awesome!
    How did you find such a park? I have considered getting a warehouse too but I don't think you can use storage places, as they do no allow it.
Lodestone Billetworks
