Results 1 to 3 of 3
Thread: Wilwood pedal box: Pros vs. Cons
    Aug 2017
    This is probably a novice question, but that's OK: I'm a novice.
    I'm optioning my kit and I notice the Wilwood Pedalbox option ($520) and do some searching on this forum. I have found a few detailed explanations about how to install it, not to permanently mount the reservoirs until the seats are in, etc, but I can't find WHY I'd want this option.
    It looks like the Wilwood setup is not compatible with ABS (which I think I want to keep). Is this true?
    Beyond that, why do I want the upgrade? Or why shouldn't I do it?
    I'm planning an 818c ('06 WRX based) that will see some track/autocross, but is being built mostly for back roads and putting a smile on my face.
    Thank you.
    Biggest reason to use it IMHO is the balance bar between front and rear master cylinders (it uses two master cylinders for the brakes). This gives you the best kind of adjustability for front to rear bias. Proportioning valves just don't work well.
    You wouldn't be able to use ABS with it unless you do some trickery on the ABS wiring and plumbing since the ABS module has two input lines, and internally, it pairs the input lines to RF/LR, and LF/RR.
    Everything Hindsight said! I have one installed -but my 818 is track focused.
    It made it much easier to select master cylinders to balance brake pressure front to rear. And having the adjuster/balance bar allows fine tuning front to rear brake balance.
    Really not needed for daily driving and there are cheaper ways to balance brake pressure front to rear: different rear calipers would be my suggestion.
    That said I'm very happy with my setup.
