I cannot find any reference to the front nose pieces in my manual other than these part no's. can you tell me where it is?
part no's 10865, 10907, and 10908
Baghdad Bob
I don't have the manual revision. Mine's a later one. Revision 3X, June 2014. But maybe it's in your manual as well. Look at the "Final Assembly" chapter (mine is chapter 5) and the "Radiator Aluminum" section. In mine, part numbers aren't referenced, but the pictures are quite clear. These pieces aren't in the usual aluminum panel installation areas, since they're installed once the body is on. Hope that helps.
