0
0
Rear Brake fitment supplied with kit
007.JPGHas anyone run into this problem installing the rear brakes supplied with the hot rod kit (11.65"). The width of the pads and the width of the rotor add up to wider than the opening in the hat. With the pads installed, and the piston I believe screwed back as far as it can go ( they are brand new so I guess the piston stats back as far as it will go to begin with) the hat will not fit down over the rotor?????
