ReinCarNation
Results 1 to 6 of 6
Thread: FE engine mounts
    FE engine mounts
    Has anyone used an after market or a side oiler block with the big block mounts provided by factory five? The reason I ask is because the left insulator, the side with the oil gallery down the block, the insulator needs to be modified to fit. Has anyone else ran into this issue?
    I used the OE one with mine and the FFR engine mounts and had about 1/2 inch clearance between the filter and thr frame
    Rick
    #8475 Complete Kit Delivered Nov 2014, 390FE, started Nov 2015, Street Legal Apr 2016, Paint and Interior Completed Aug 2017, March accessory kit, MSD Atomic EFI and Ready to run, TKO 500 with MidShift kit, 3 link, track lock with 3.55
    Rick
    Is your block as side oiler? The left insulator hits where the top bolt goes on the front. Looks like the only way to make it work is to trim insulator.
    Mine is the 390 top oiler but from what I've read the top oiler and side are oiler have the same block castings except for the oil passages
    I had no issues using the FFR mounts with the OE oil filter adapter the rubber parts of the mount cleared the block with no problem
    I did have to grind down part of the block to get the high torque starter to mount
    Did you use the 4.6 liter panel for the drivers foot box you will need the added space for header clearance
    My engine mount came in two pieces
    The rubber mount has two plates the one with four holes bolts to the block and the plate with two holes bolts to the other bracker with the threaded stud pointing out towards the frame mount
    I can try and get you a pic later today
    Rick
Vintage Wheels
