Results 1 to 2 of 2
Thread: '97 Pedal box question.
    Ready to install my 1997 donor pedal box after modification per the build manual. The plate behind the removed spot welded plate has a welded/pressed in stud located in the left lower mount hole. Is that supposed to be deleted or is it needed for the Hydro boost unit? Have diligently searched the forums pertaining to this but have found no hits. The Hydro boost mount studs are all there so it looks like this errant stud on the box will interfere with the HB install? All pics in related posts show no permanent stud at that location.
    Help guys!
    Mar 2017
    Spicewood, Texas
    You need to remove that stud. It can just be pressed out.
    LS1, TKO600, IRS, no scoop, undercar exhaust. Delivered June 14, 2017, First start December 31, 2017, Registered and Titled Sept 12, 2019.
