Thread: Time to Get Serious With The Fuel System
    I now have the engine and FAST EFI in my shop and I need some advice on component placement.
    Here is the fuel pump that came with my engine and EFI.
    It looks like I could mount this into an in-tank bracket rather than externally. I was looking at this kit from Breeze:
    http://www.breezeautomotive.com/details.php?prod_id=402
    I also received a fuel filter, pressure regulator, and pressure gauge. Can anyone recommend placement for these items? I believe the filter is intended as a post-pump filter if mounted externally.
    I also have a Holley 100 micron filter that I purchased to replace the FFR kit filter. Any issue running that as well as the smaller filter if I mount the pump in the tank?
    Delivered: 6/17/2017
    First Start: 12/30/2017
    Completed: 12/7/2019
    Legal: 1/30/2020
    That pump is quite different than the pumps (e.g. Walbro) that are typically mounted on an in-tank hangar like that, and likely wouldn't fit. I wouldn't even be sure it's designed to be fully immersed. I would recommend mounting it externally as it's intended. That would mean a simple pickup in the tank with a mesh strainer. Then a single external filter in the fuel line upstream from the pump. EFI typically requires a fine mesh, like 10 micron. The regulator and gauge are typically underhood.
    Maricopa AZ
    Use a 255lph in take pump and the Mustang hanger. Give me a call and I help with the correct stuff.
    Quote Originally Posted by Gordon Levy View Post
    Thank you, gentlemen. If I decide to just use the parts that I have and not go with an internal tank pump, where should I mount the fuel pump? Is orientation (horizontal or vertical) critical?
    Legal: 1/30/2020
    Maricopa AZ
    Horizontal, needs to be as low and the bottom of the fuel tank. Need to mount to something solid. Most likely you will end up making a bracket.
    Thanks, Gordon. After trying to figure out how to make things work with what I already have, I think going with your recommended system is my best bet. Thanks for the recommendation and I'm looking forward to seeing what you send me!
    Legal: 1/30/2020
    Lost Wages, Nevada
    Pretty sure the pump you have pictured is EXTERNAL USE ONLY (fittings on both ends), and more-than-likely, NOT rated for immersion in any type of fuel.
    If the straps shown came with the pump (as a kit), it's definitely an external pump with a sound-deadening sleeve.
    Just my 2¢
    Doc
    Quote Originally Posted by Big Blocker View Post
    Just my 2¢
    Doc
    Doc,
    I'm ditching the pump and the FFR filter and lines and going with a setup from Gordon Levy. It's going to include an in-tank pump, hanger, and lines. I'm going to have a lot of stuff to sell when this build is done.
    Legal: 1/30/2020
    RJD's Avatar
    Northern Virginia
    Great post Papa. I'll be going with the Fast ezEFI set-up as well, so I'm taking notes. Thank you.
