0
0
Engine Install Prep
So I need to ask...do the isolation blocks for the engine get mounted to the engine and then bolted to the engine brackets as the engine is installed or is everything mounted to the chassis and then just the final (4) four bolts from the iso blocks to the engine get installed? I have electric steering and it seems like it is going to be extremely difficult to tighten the (1) bolt on the iso blocks once installed...was thinking that there may be more access to the (4) mounting bolts on the engine, but then again may lose the ability to adjust fit up. Would also like to hear any additional suggestions for prepping to install the engine...hope to do so by the end of the month.
33' Hot Rod Coupe/Roadster (GEN 1), Fendered, Ford 302, 350hp, EFI, AOD, 4-Link, Double Adjustable Koni Coilovers, Split Rear Exhaust, Electric Power Steering, AC/Heat/Defrost, Moser 8.8"-3.55, Willwood Front/Rear Brakes, 18" x 8" Fronts/20" x 10" Rears, Ordered: 1.26.17, Arrived: 3.29.17, First Start: 7.2.18, Go Cart: 11.4.18 Paint/Body: 2.23.19, Back Home: 11.24.19, Completed: NEVER!; View More Pics @
https://starmobileone.com/
