Results 1 to 3 of 3
Thread: Engine Install Prep
    Senior Member JOP33's Avatar
    Haslet, Texas
    Engine Install Prep
    So I need to ask...do the isolation blocks for the engine get mounted to the engine and then bolted to the engine brackets as the engine is installed or is everything mounted to the chassis and then just the final (4) four bolts from the iso blocks to the engine get installed? I have electric steering and it seems like it is going to be extremely difficult to tighten the (1) bolt on the iso blocks once installed...was thinking that there may be more access to the (4) mounting bolts on the engine, but then again may lose the ability to adjust fit up. Would also like to hear any additional suggestions for prepping to install the engine...hope to do so by the end of the month.
    May 2016
    North of sacramento Ca.
    I put mounts on engine first, trans later.
    Seasoned Citizen NAZ's Avatar
    I've had my SBC / TKO trans combo in and out of my hot rod a few times now and always attach the mounts first (engine & trans). Once positioned I install the FFR engine brackets then align the trans mount and tighten it. For you build you also need to determine if you should position the headers before dropping in the engine. Mine are different than yours and go in last which makes the job very easy. For my combo the tight spots are the shifter stub hitting the firewall crossmember if not careful and the low oil pressure switch hitting the firewall if not watching close. I install the assembly through the front with the grill assembly removed and I have it down to a one-man job but it is easier if I have my wife help me watch the tight spots.
