Results 1 to 15 of 15
Thread: Cutting IRS Spindeles
    Senior Member Tampa33Build's Avatar
    Feb 2017
    Lutz, Florida
    I'm installing the FFR IRS system in the 33 hot rod (no donor parts). Page 76 and 77 of the manual shows cutting the spindle for the IRS installation. Before I cute off part of the spindle, I want to make sure it is correct. Additionally,why is this cut needed?
    Thank you,
    Neil
    Yes it's correct. The FFR designed upper control arm doesn't use this connection and in fact would interfere with their setup. These pictures are from my Roadster build, but the same for all.
    I cut mine using a bandsaw. Left a little more material than explained in the instructions. Still fit fine:
    Then cleaned up a bit:
    With the UCA attached:
    FWIW, this is the stock Mustang setup, and how those two spindle connections are used. Very different from the FFR setup.
    Feb 2017
    Lutz, Florida
    Thanks for the reply and photos. I was hesitant cutting them, could not understand why FFR designed a frame for the IRS and requires cutting the spindle.
    Neil
    Aug 2020
    Phoenix, AZ
    Paul, would you mind sharing what you used to clean up the cut ends of the spindles. Those look really clean and finished up very nicely!
    Quote Originally Posted by Jammer369 View Post
    Held them against my Delta disk/belt sander until the saw marks were gone. Then sanded with several grits of paper and a sanding block including breaking the edges some.
    Aug 2020
    Phoenix, AZ
    Thanks for the info. They almost looked polished!
    Dreamer j33ptj's Avatar
    Wassenaar, The Netherlands
    The current manual does not state this anymore, wonder what has changed (this thread started in 2017...)
    Quote Originally Posted by j33ptj View Post
    Yes, post has been around. But Factory Five hasn't changed the design of the suspension. Without that area trimmed off on the knuckles, they would interfere with the upper control arm attachment and most specifically the adjustment sleeves/nuts that are on the end of the upper control arm. What instructions are you looking at? Don't have the most recent Roadster or Coupe manuals. But the IRS instructions on their website haven't changed. https://www.factoryfive.com/wp-conte...2015-REV-D.pdf
    Sorry, looked at the wrong pages.... need to check better before opening my big mouth...
    Senior Member 32J's Avatar
    Dec 2018
    Sherwood Park, AB
    I wonder if the manual should also mention, "If you are installing an IRS brake package, you may also have to cut off the top brake caliper ear on the spindles." It would be easier to do all the cutting, grinding, sanding, polishing (and in my case, Cerakoting) in one step before mounting.
    Quote Originally Posted by 32J View Post
    I wonder if the manual should also mention, "If you are installing the 2015 IRS Wilwood brake package, you will also have to cut off the top brake caliper ear on the spindles." It would be easier to do all the cutting, grinding, sanding, polishing (and in my case, Cerakoting) in one step and BEFORE I mounted the spindles to the IRS.
    Would like to know more about this. I've done two IRS builds with the upgraded Wilwood package (a Roadster and a Coupe) and did not have to cut the brake caliper ear. In fact, as I remember the 249-15139/40 brackets bolted to those ears. Need to dig out the instructions to confirm since I can't find any pictures. But maybe you could provide more details? Something maybe has changed. Would hate to see someone cut and find they're needed.
    Simi Valley, CA
    FWIW, I have a '33 Hot Rod with the 2015 IRS and Wilwood brakes purchased in 2016 - 2017. I did not have to cut off the caliper ear to install the brakes. Maybe something has changed since then?
    Keith HR #894
    Jun 2018
    North Vancouver, BC, Canada
    Same a Keith, IRS with Wilwood brake package, only had to cut off what Paul (edwardb) has shown, no other ear to cut off.
    I didn't have a band saw but tried using a sawzall, wasn't fun but got the job done. The real pain the butt modification on that spindle was drilling out one of the holes!
    Gen 1 '33 Hot Rod #1104
    Dec 2018
    Sherwood Park, AB
    The 2015 IRS brake instructions from the FFR site mentions cutting the spindles. A tech at F5 then sent me a different set of instructions, which did not indicate cutting the spindles. They were still the wrong instructions for the brakes I was actually supplied by F5. Eventually I found the correct instructions. Not a problem for experienced builders, but being a newbie I was a bit anxious. I edited my post above, as the instructions on the F5 site (where spindles have to be cut) are intended for some combination of IRS and brakes (not mine, thankfully).
  15. Likes FF33rod liked this post
  16. #15
    Jun 2018
    Glad you got it sorted!
