Took forever but finally got the car back from the painter, but have noticed that I have less clearance on the passenger side for the tires clearing the fender, is this common.IMG_0529.JPG
I like the color scheme!
Looks good.
Can you describe your tire clearance issue in a little more depth?
Good looking car!
Sorry, I am not going to help with your clearance issue at all. BUT.....that is a cool color scheme. You won't see many like that. Very nice.
Oh. good luck with the clearance issue. I did not have a problem.
You didn't say whether you're dealing with front or rear. Body position on the chassis, alignment (including rear if IRS) and panhard bar adjustment on 3 link all come into play. More info about your specific issue will help.
it's the passenger side front that is closer to the fender. I mean as far as with not height. The lower control arms are from a mustang donor, so I can't adjust them, only the upper arms. I have not had it aligned yet.
thanks jeff, it might be a while before i get it aligned but i will do the measuring and see what i got
