Results 1 to 2 of 2
Thread: E-brake issues
    Senior Member Lowrod's Avatar
    Nov 2015
    Mount Olive AL.
    E-brake issues
    Ok guys what am I missing?
    Set-up: Donor E-brake assembly out of a 92 Convertable with cable (not sure if it was a V8 Car)
    Rear end was out of a 93 GT Fox hard top. I installed a the 5 lug conversion, drum brakes with stock E-brake cables
    Issue: After E-brake Handel install in Roadster, handel is almost vertical before IT STARTES TO ENGAUGE!
    Ive installed the E-brakes before and never had an issue in older MK2's and MK3's. This is my first MK4, what is the difference?
    Thanks Guys
    Heart of Dixie, Alabama
    Hey Lowrod. I have read that the Ford ratchet e brake handles have a self adjusting ratchet inside. I have not had any experience with it, but you might find something on google or you tube. I am just up the road from you, near Warrior. We need to compare notes sometime.
