0
0
E-brake issues
Ok guys what am I missing?
Set-up: Donor E-brake assembly out of a 92 Convertable with cable (not sure if it was a V8 Car)
Rear end was out of a 93 GT Fox hard top. I installed a the 5 lug conversion, drum brakes with stock E-brake cables
Issue: After E-brake Handel install in Roadster, handel is almost vertical before IT STARTES TO ENGAUGE!
Ive installed the E-brakes before and never had an issue in older MK2's and MK3's. This is my first MK4, what is the difference?
Thanks Guys
