Thread: Instructions for 302 Compound
    Mar 2014
    Pass Christian, Mississippi
    Had good results with this stuff, 302 compound, but cannot recall the exact way i applied. I do have the instructions on the can but would like any help or tips from users. Thanks. Henry
    MK IV complete kit delivered August 21st, 2014. Ford Racing 427w with X heads. IRS. Upgraded Wilwoods, 6 piston front and 4 rear. Tremec t600 and Ram Dual clutch. Holley Terminator EFI.
    I've used it several times. Don't recall doing anything special. Wiped it on. Let it sit a little. Wiped it off. It does its thing via chemical reaction. So rubbing or polishing isn't required. Also recommended to neutralize with water or soap. I also wore gloves. Just based on the smell, didn't think I wanted it on my bare skin.
    Found these directions with a search. Pretty much what I remembered. Now that's scary. https://www.mplso2.com/assets/downloads/ARC-302.pdf
    Jax Beach, FL
    I have used it. It works great, even on a 347.
    I took a piece of cardboard and made a cutout to go around where the pipes exit the body to protect the paint. I rinsed it sown with soapy water.
    Gloves and safety glasses. I wouldn't want that stuff on my paint, skin, or eyes.
    Senior Member broku518's Avatar
    Jupiter, FL
    Stupid question, what is 302 compound?
    Quote Originally Posted by broku518 View Post
    Click on the link in post #2 and read it.
    HTH
    Jupiter, FL
    doh!, thanks.
