Thread: TKO-600 tail housing
    Calgary, Canada
    I have a small leak between tail housing and main transmission body. Can the tail be removed under the car without pulling the engine and transmission completely?
    Santa Clarita, CA.
    Here is a thread addressing this exact problem. Make sure to use the correct anaerobic sealant. If it's not mentioned I will update post when I get home. I have used the correct sealant and should have the part number at home.
    http://www.ffcars.com/forums/21-ffr-...tml#post224114
    Calgary, Canada
    Thank you! That thread makes it sound easy. Id be grateful for the correct sealant part number and make. Thanks
    Santa Clarita, CA.
    Loctite 518
    Here is some more info. More related to the front where mine leaked but still good info.
    http://www.moderndriveline.com/Docs/...503-06_131.pdf
    Calgary, Canada
    Thank you Sir,
