Getting prepped to install the rear end. I'm a bit confused as to which bolts to use. As you can see from the pic I've set aside 4 brass colored bolts (2 long & 2 short) for the job. The 2 front mounts are OK since the instruction indicates drilling ⅝" holes to expand the existing holes (B in the pic). Here I will use the long bolts. The rear mounts are the issue (A in the pic). While they are threaded, the two threads on the short bolts don't even come close to screwing into the threads of the mounts.
I'm lost.
