Results 1 to 8 of 8
Thread: Coyote Powered Mk4 Roadster - Recommended upgrade kits from Breeze Automotive
    Mar 2013
    Medway, MA
    From time to time I get the question: What Breeze items should I get for my complete Mk4 Roadster with Coyote power, and why? The answer is too long for a phone call and the list is so varied I even forget a lot of the items. Also, and even with the Breeze Automotive website EzeSearch function, some great items can be overlooked. So for your education and entertainment and so you can build a better roadster, I’ve compiled the following list:
    70634 Solid Offset Rack Mounting Kit (Why? better handling, less bump steer, more rigid frame)
    http://www.breezeautomotive.com/details.php?prod_id=720
    70561 Engine Compartment Battery Mounting Kit (Why? less weight, better weight placement, lower center of gravity, eliminates need for remote terminals and cut-off switch due to easy access)
    http://www.breezeautomotive.com/details.php?prod_id=518
    70019 Dash Support Brackets (Why? supports flimsy dash, place to mount hidden switches or lights)
    http://www.breezeautomotive.com/search.php?search=70019
    70734 190 LPH In-Tank Fuel Pump Assembly (Why? perfect size for Coyote engine with Mustang tank, supports 470hp and can still use stock ¼” return)
    http://www.breezeautomotive.com/deta...p?prod_id=1105
    70748 Fuel Line Assembly, EFI Pump to Filter, 3/8" - 3/8" Quick Connect (Why? 1 minute installation, allows dropping of tank for service)
    http://www.breezeautomotive.com/deta...p?prod_id=1132
    70766 Coyote Fuel Filter Pressure Regulator and Line Kit (Why? attaches direct to return port so only 1 fuel line needs to be run to the front, robust and simple high flowing braided stainless steel Teflon line hose)
    http://www.breezeautomotive.com/deta...p?prod_id=1185
    35314 Zero Clearance Insulation (Why? reflects radiant heat before it gets to the foot-box aluminum)
    http://www.breezeautomotive.com/details.php?prod_id=773
    35391 BiMat Aluminum 2-Layer Dampening System (Why? stops noise and ringing for a solid feel)
    http://www.breezeautomotive.com/details.php?prod_id=838
    35392 QuadMat 4-layer Dampening System plus Thermal Insulation/Cushioning (Why? adds comfort under carpeted surfaces you will be touching)
    http://www.breezeautomotive.com/details.php?prod_id=839
    70551 Lower Radiator Support Kit (Why? we support our radiators!, easy adjustment, rugged dampened mount independent of body)
    http://www.breezeautomotive.com/details.php?prod_id=494
    70558 HD Hinged Upper Radiator and Shroud Mounting Hardware Kit (Why? reinforces upper radiator channel, allows easy angle adjustment without stressing the radiator, handy high quality stainless fasteners)
    http://www.breezeautomotive.com/details.php?prod_id=162
    32204 Radiator Fan Shroud (Why? provides un-obscured fan mounting and to draws air over entire area of radiator, supports radiator core by tying upper and lower channels together)
    http://www.breezeautomotive.com/deta...p?prod_id=1117
    70528 Splined Quick Release Steering Wheel Hub Kit (Why? locking wheel in trunk best anti-theft device, improved ingress/egress for some, and its racy!)
    http://www.breezeautomotive.com/details.php?prod_id=413
    70602 Seat Installation Kit (Why? reclined position adds comfort, adjustable for different drivers and makes seat removable from the cockpit side for the occasional thorough cleaning or drying)
    http://www.breezeautomotive.com/details.php?prod_id=609
    70752 Storage Cubby Kit (Why? infinitely increases cockpit storage space, utilize wasted trunk area)
    http://www.breezeautomotive.com/details.php?prod_id=861
    35201 Traditional Style Hood Hinge Kit (Why? Holds front of hood down better, no stress when closed from gas struts, moves hood out of hood opening when up, less expensive)
    http://www.breezeautomotive.com/details.php?prod_id=589
    35512 Driver Side Hood Prop Rod Kit (Why? compliments the passenger side prop included with hood hinge to allow clear access for engine bay service from the opposite side)
    http://www.breezeautomotive.com/deta...p?prod_id=1156
    70696 Radiator Cowl Cover for use with Traditional Hood Hinges (Why? directs cooling air through radiator, prevents hot air recycling, cleans up engine compartment)
    http://www.breezeautomotive.com/details.php?prod_id=948
    35303 Billet Side View Mirror Set (Why? give outstanding view to sides and rear, avoids need to drill into your fresh $8K paint job, outstanding quality and a pleasing design)
    http://www.breezeautomotive.com/details.php?prod_id=757
    35438 Roll Bar Parts Kit with optional harness crossbar 35460 (Why? just looks right, avoids paper clip look, crossbar provides higher shoulder harness attachment point for tall or long torso drivers, fool brand guessers)
    http://www.breezeautomotive.com/search.php?search=35438
    35376 Wilwood Remote Brake Balance Bar Adjuster (Why? easily adjust your brakes for maximum stopping power, safety)
    http://www.breezeautomotive.com/details.php?prod_id=836
    35490 Cobra Shift Knob (black) or 35489 (white) (Why? shift pattern faces driver instead of dash, officially licensed engraved Cobra logo looks badass)
    http://www.breezeautomotive.com/deta...p?prod_id=1078
    http://www.breezeautomotive.com/deta...p?prod_id=1077
    70762 Coyote Gas Pedal (Why? rectangular pedal for a rectangular space)
    http://www.breezeautomotive.com/deta...p?prod_id=1155
    70753 Dead Pedal Kit (Why? have a place to rest your left foot)
    http://www.breezeautomotive.com/deta...p?prod_id=1140
    70703 Hydraulic Parking Brake Kit (Why? convenient to operate from driver seat, may allow you to skip the handle and cables – check local laws first)
    http://www.breezeautomotive.com/deta...p?prod_id=1000
    35247 Trunk Prop Rod (Why? to hold your trunk lid up silly!)
    http://www.breezeautomotive.com/details.php?prod_id=662
    If you were to install most or all of these items you can pretty much call your Roadster a MkV!
    Feb 2017
    Kansas City, MO
    Thanks for putting this together. I see a number of items that will be useful.
    Feb 2017
    Everything Mark makes is top notch, and his customer service is exceptional.
    Conesus, NY
    Already have a bunch of the items and found a few more to order!!
    Chuck Krueger
    2000 C5
    2003 C5 Z06
    2007 C5 Z06
    Mar 2013
    Medway, MA
    The Breeze 70602 Seat Installation Kit is now easier to install and is more comfortable than ever!
    If you are getting ready to install your FFR Roadster seats now then today or tomorrow is a good time to order.
    Free domestic shipping on all orders placed now through Friday 11/10/17.
    Breeze Automotive Factory Five Racing
    Folsom, CA
    bump! time to update some links
    looking for the battery box to go on sale again
    Todd
    Oct 2020
    Greensboro, NC
    Wow, some of these are great. Too bad the links are dead.
    Quote Originally Posted by copythat View Post
    Three year old post. Mark completely revamped his website since then. Nice improvement. You can search his website on the part numbers he provided in the list.
