Results 1 to 4 of 4
Thread: Brake line help
    Brake line help
    My father and I are about a year into our build on our gen 2 coupe.
    We are having some disagreements about how to run the brake lilned. I was hoping to get som advice and maybe some pictures on how other people have routed their brake lines. Specifically about how to pass the hardline through the firewall. We have the willwood pedal box with dual brake master cylinders
    mcwho's Avatar
    DeBary - Florida
    TJ,
    JUst realized you are building a coupe, so some of this may or may not apply...I built a MK4 roadster.
    My son and I co built my car Early on we shared the install of the IRS pumpkin and f and r brakes.
    I did the brake lines myself with the help of the eastwood flaring tool.
    I routed the brake and fuel lines from the tank up across a rear frame member to the drivers rear weel where I have a 3 way connector. From there I ran the lines on the outside of the 4" frame tube to the rear of the front part of the footbox there is a place where you can transition from the e 4" tube to the left chassis and up through the area where the steering shaft goes thru the left firewall.
    I have a hydraulic clutch and power brakes and it seemed logical to have all the lines go up the left side as thet is where the brake lines and fuel line terminates
    I didn't want either to be too exposed in the engine compartment.
    Baghdad Bob
    Northern CA
    You have a couple of options to pass a line thru a firewall. You can pass the line thru by just drilling a hole large enough to pass the line with a fitting already attached. In this case you would also need to insure that the line does not chafe against the panel, and this would require a rubber grommet of the appropriate size. The one that I use the most is a bulkhead fitting, (see attached pictures), this just requires a hole in the firewall that the threaded portion of the fitting requires. Long portion thru the hole, held in place by a nut on the long threaded portion. These fitting are for an "AN" system, but the same applies for SAE (Double Flare) systems, but they will be harder to find.
    Then you attach the appropriate lines from either side. There are a "Y" fittings to split the line into two directions such as the two front or rear brakes. Always use Steel or Brass Fitting on a brake system!
    Hank
    Senior Member Rodster's Avatar
    Orange County, CA
    Brake line routing
    No need to drill holes, I think. Mocking the lines using stiff wire and masking tape to hold them in place helped a lot when I did mine. Saved a lot of time and brake lines, and I did it all in one shot, no "do-overs."
    These pics might help. See the "slot" in the sheet metal firewall? Go under or inside that. Patch the slot later. Cut a hole or slot around the brake line and line the hole with a grommet if needed.
    Hankl does have a great suggestion, though. Those fittings will look very nice under the hood. . .
    Ordered Type 65 Complete Kit Aug 29, 2012 - The 50-50 $ale!
    Standard Width IRS; Halibrands - 17x9, 17x10.5
    Kit Arrived: Oct 9, 2012; Build Started: Oct 28, 2012
    WordPress: http://wayne-yoshida-kh6wz.com/
    LinkedIn: www.linkedin.com/in/waynetyoshida
    YouTube: http://www.youtube.com/user/kh6wz?feature=results_main
