Engine Factory
Results 1 to 12 of 12
Thread: Fuel tank capacity
    Burlington, WI
    Fuel tank capacity
    I pulled into a Service station to fill the tank. It took 14.5 gallons, but I thought I had at least another gallon or so left in the tank. Could the current tank be 18 gal capacity. If not, yikes, I made it just in time.
    14.6 plus a little on the fuel neck
    Go Fast Part and tech Specialist [email protected]
    http://www.facebook.com/levyracing www.levyracing.com
    Completed over 195 FFR builds in the last 21 years and still counting
    Burlington, WI
    Quote Originally Posted by Gordon Levy View Post
    I will say it again....yikes. I was apparently cutting it very close.
    Creedmoor, Texas
    You might want to adopt the 1/4 tank is empty. At least you didn't have to push it.
    Texas Cobra Club-Austin
    Burlington, WI
    Quote Originally Posted by seagull81 View Post
    Good idea. And, as it was a busy day in downtown Lake Geneva traffic, I really dodged a bullet.
    Not sure what the complete kit comes with but most of the mustang tanks are 15.4 Gallons.
    Woodstock ,Illinois
    Jay, I love driving in downtown Lake Geneva! All those cars diagonally parked with the alarms on... do I need to say more?!
    FFR 5136 Started as a donor...donor guages, engine, trans,etc. Now...TFS street intake,stage 1,GT40p's,24# injectors and 73mm MAF,70mm TB,Z-spec t-5,cobra r's riding on BFG KDW's. What's next?
    Burlington, WI
    Quote Originally Posted by steno View Post
    Steno,
    I never gave it a thought, but now I'll have to try it ... at least once. Trouble maker!
    Senior Member 2bking's Avatar
    Garland, Texas
    I've put 14.95 in my tank a couple of times and the gauge showed about 1/8 tank before filling.
    King
    Quote Originally Posted by 2bking View Post
    Wow, talk about playing it close.
    Saturday morning my gas gauge was midway between the 1/2 and the 1/4 mark and it took 10.2 gallons to fill. That's about as low as I let it go before looking for a gas station. If it get's to the 1/4 mark I figure I have about 3 gallons left and I better be sitting at the pump.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Jay - Just to make sure your build it period-correct, I'm going to get you a stick like they used on the original cars to check the fuel level.... you may have trouble getting it down that filler neck, though. LOL ;-)
    Later,
    Mk3.1 #7074
    Not a waxer
    Jeff Kleiner's Avatar
    When I build using the Speedhut gauges I do the manual calibration and set the "empty" point with about 2 gallons in the tank then fill it and set "full".
AJW
