Results 1 to 12 of 12
Thread: Fuel tank capacity
    Burlington, WI
    Fuel tank capacity
    I pulled into a Service station to fill the tank. It took 14.5 gallons, but I thought I had at least another gallon or so left in the tank. Could the current tank be 18 gal capacity. If not, yikes, I made it just in time.
    Road Legal August 31, 2017
    Maricopa AZ
    14.6 plus a little on the fuel neck
    Burlington, WI
    Quote Originally Posted by Gordon Levy View Post
    I will say it again....yikes. I was apparently cutting it very close.
    Creedmoor, Texas
    You might want to adopt the 1/4 tank is empty. At least you didn't have to push it.
    Texas Cobra Club-Austin
    Burlington, WI
    Quote Originally Posted by seagull81 View Post
    Good idea. And, as it was a busy day in downtown Lake Geneva traffic, I really dodged a bullet.
    Not sure what the complete kit comes with but most of the mustang tanks are 15.4 Gallons.
    Woodstock ,Illinois
    Jay, I love driving in downtown Lake Geneva! All those cars diagonally parked with the alarms on... do I need to say more?!
    Burlington, WI
    Quote Originally Posted by steno View Post
    Steno,
    I never gave it a thought, but now I'll have to try it ... at least once. Trouble maker!
    2bking's Avatar
    Garland, Texas
    I've put 14.95 in my tank a couple of times and the gauge showed about 1/8 tank before filling.
    King
    Member Frank Messina's Avatar
    Yorba Linda, CA
    Quote Originally Posted by 2bking View Post
    Wow, talk about playing it close.
    Saturday morning my gas gauge was midway between the 1/2 and the 1/4 mark and it took 10.2 gallons to fill. That's about as low as I let it go before looking for a gas station. If it get's to the 1/4 mark I figure I have about 3 gallons left and I better be sitting at the pump.
    FFR 4440 - V8, Manual Trans, Htr, WSW, IRS. I wouldn't change a thing.
    Out Drivin' Gumball's Avatar
    Blackberry Township, IL
    Jay - Just to make sure your build it period-correct, I'm going to get you a stick like they used on the original cars to check the fuel level.... you may have trouble getting it down that filler neck, though. LOL ;-)
    Later,
    Mk3.1 #7074
    When I build using the Speedhut gauges I do the manual calibration and set the "empty" point with about 2 gallons in the tank then fill it and set "full".
